12V At Spotlights But No Light :(
7 replies to this topic
#1 trashy
trashy
  • Just Joined
  • 30 posts
Posted 08 November 2020 - 02:21 PM
Mini Cooper RSP (1990) spotlights - replaced the bulbs but still no light when on full beam :(
Verified that I have 12v across the terminals.
Verified that the bulbs work by connecting to old battery.
Any other ideas?  Thanks!
Edited by trashy, 08 November 2020 - 02:22 PM.
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 08 November 2020 - 02:24 PM
If you are getting power to the bulbs, and we know the bulbs work, I suspect you have a bad earth.
#3 trashy
trashy
  • Just Joined
  • 30 posts
Posted 08 November 2020 - 03:28 PM
Thanks - you're probably correct.   Both 12v and earth enter the loom near the bulkhead. Are there any earthing points that are worth checking/cleaning?
Edited by trashy, 08 November 2020 - 03:30 PM.
#4 Maccmike8
Maccmike8
  • 1,101 posts
Posted 08 November 2020 - 04:32 PM
Use a multimeter or test lamp to work backwards from the earth wire in the lamp.
#5 NDT
NDT
  • 188 posts
Posted 09 November 2020 - 10:55 AM
Check resistance of the wires.
I once spent days tracking down a wiring fault on my VX220 engine management loom. I checked voltage at the terminal and everything was 12v.
It turned out one of the wires was corroded inside - the resistance was 1000's of times higher than it should have been - the 12v at no current would have been virtually 0v as soon as any current flowed.
#6 andyapanel
andyapanel
  • 626 posts
Posted 09 November 2020 - 12:45 PM
Check the bullet connectors.
I get rid of them and solder the wires together.
I also run in a couple more earths, just to be on the safe side. The last thing you want is to lose lights this time of year.
I like to keep my RSP as original as possible, but as this is safety related, I think it is worth the sacrifice. I would also recommend looking in to a Wired by Wilson relay kit for your lights; melting light switches are SO smelly.
#7 trashy
trashy
  • Just Joined
  • 30 posts
Posted 11 November 2020 - 07:42 AM
Thanks for your tips  - will be looking at this over the weekend and will report my findings!
#8 trashy
trashy
  • Just Joined
  • 30 posts
Posted 18 November 2020 - 11:28 AM
Turned out that the 12v live connection to the relay was bad - some contact cleaner and a waggle seems to have cured it.  Thanks for all your help.
Edited by trashy, 18 November 2020 - 11:55 AM.
