Gear Bobbins
8 replies to this topic
#1 mrmeds
mrmeds
  • 253 posts
Posted 08 November 2020 - 09:01 PM
probaly a silly question, but whats the easiest way of replacing these ?
do you have to jack the car up and remove the whole gear selector mechanism or can you access them through the hole in the floor ?
thanks
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 08 November 2020 - 09:08 PM
No need to remove the whole assembly, make it accessible from the inside, Tie the assembly up, undo the nuts on the inside, jack the car up, undo the other nuts on the bobbins, fit new ones. It's made easier with an extra pair of hands so you can tighten the nuts up on the inside while the bobbins are held with grips.
#3 nicklouse
  • 18,696 posts
Posted 08 November 2020 - 10:26 PM
Gear bobbins? What are they?
#4 Bobbins
Bobbins
  • 1,511 posts
Posted 09 November 2020 - 07:32 AM
Here: http://www.minispare...ic/22G2205.aspx
#5 mrmeds
mrmeds
  • 253 posts
Posted 14 December 2020 - 08:54 PM
gear bobbins now installed, can reverse up the drive again- but still drops out of second if going down hill and no foot on the gas ! Is the steady rod adjustable- wondering if this could be the problem- anyone any ideas ?
Ta
#6 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 14 December 2020 - 09:28 PM
If the bobbins have gone maybe the rubber in your steady rods has gone as well causing excess rocking of the engine?
#7 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 14 December 2020 - 10:06 PM
Try new bushes
#8 nicklouse
  • 18,696 posts
Posted 14 December 2020 - 10:08 PM
Ta
I would say that is more likely to be the synchro that is worn not holding it in gear.
but check engine mounts and stabiliser bushes first. The bush at the back of the diff rarely fails but check it for play as well.
#9 mrmeds
mrmeds
  • 253 posts
Posted 14 December 2020 - 10:11 PM
Ta
that was my first thought back in march, got a recon box fitted so hopefully not that !
