Durite 3 Terminal Starter Solenoid
4 replies to this topic
#1 croc7
croc7
  • 817 posts
Posted 09 November 2020 - 08:24 AM
I’ve been looking for a three terminal Durite starter solenoid but I’ve only been able to find P/N 0-335-02, which is four terminal. I’m not sure of the purpose of the fourth terminal, Product description says ‘cold start’-don’t know what that means. Should I cap it off? Is it a necessary earth connection? The solenoid is supposed to be a replacement for P/N 13H5952. Thanks
Edited by croc7, 09 November 2020 - 08:28 AM.
#2 GraemeC
GraemeC
  • 7,440 posts
Posted 09 November 2020 - 08:42 AM
Provides a 12V output during cranking - used for ballast type ignition systems.
It will work fine in place of a 3 terminal solenoid, just don't connect anything to this 4th terminal.
#3 croc7
croc7
  • 817 posts
Posted 10 November 2020 - 08:36 PM
Thanks for the reply.  Is there a reason that I shouldn't drill out the 4th terminal solder/tab and plug the hole or would that disable the solenoid?
#4 Dusky
Dusky
  • 5,322 posts
Posted 10 November 2020 - 08:43 PM
Just leave it. Only live on cranking.
#5 croc7
croc7
  • 817 posts
Posted 14 November 2020 - 06:13 AM
For what its worth, I found a Durite three terminal solenoid, p/n 0-335-00. Looks like all you have to do is remove the large spade connectors from one of the large post terminals and you’re in business.
