Primer On Bare Metal
7 replies to this topic
#1 Landyboy007
Landyboy007
  • 29 posts
Posted 10 November 2020 - 12:49 PM
Hi,
I’ve bought an expensive epoxy primer to spray onto the bare metal shell. I’ve applied the first coat, is three coats enough?
Also do I need to spray on another type of primer over the epoxy or can the top coat go straight on it?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,040 posts
  • Name: Neil
Posted 10 November 2020 - 02:38 PM
You won’t need three coats of epoxy. One should do followed by a filler primer.
#3 Vanman20
Vanman20
  • 274 posts
Posted 10 November 2020 - 06:47 PM
Like most paints there'll be a window for overcoating.
For example lechler 29107 epoxy can be over coated without sanding if it's within the 24 hour window, otherwise it needs a light sanding.
Check the TDS of your particular product
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,026 posts
Posted 10 November 2020 - 07:00 PM
I've recently sprayed panels with custom 421 (https://www.rust.co....om-421-grey--36) epoxy primer. I rang them and they said 2 coats minimum. Pretty sure you can spray straight on top, depending on the paint.
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 November 2020 - 07:42 PM
Is the epoxy a sanding or non sanding type?
If it's a sanding type, you can apply more as it has build so can be treated like high build primer.
If its non sanding, you wont need any more than 2 coats. Just make sure that the first coat is light followed by a full coat
#6 Landyboy007
Landyboy007
  • 29 posts
Posted 11 November 2020 - 07:31 PM
Thanks guys, applied 3 coats and will sand down with fine grit.... what is the best grit? 3000?
#7 sonscar
sonscar
  • 3,002 posts
Posted 11 November 2020 - 08:23 PM
400 to 600 depending on your topcoat system would be my uneducated choice.3000 may not have enough "bite", Steve..
#8 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 November 2020 - 08:51 PM
400 is my preference if dry sanding.
800 if wet sanding
