Carb Conversion Problems
Posted 10 November 2020 - 09:25 PM
Posted 10 November 2020 - 11:18 PM
Being honest the SPI system is very basic and with a multimeter and the correct diagnostic plug (£40 all in, for the plug and application for your phone) can be repaired.
YouTube DB mini DIY for all there is to know about the SPI and diagnosis
Running on is an issue, you are doing the correct thing by stalling the motor, however you can minimise the frequency of it by leaning out the mixture (set accordingly for year of car) and tweaking the timing.
You say you still have the ecu fitted. If you have carb converted the engine you don't need the ecu.
Edited by cal844, 10 November 2020 - 11:23 PM.
Posted 10 November 2020 - 11:52 PM
Edited by Callump, 10 November 2020 - 11:54 PM.
Posted 11 November 2020 - 12:58 AM
It does sound like the mixture is out at low revs.
Your exhaust pipe is a little too large for that engine, especially at low revs and a 1.75" is generally accepted as best for a 1275 engine unless it is in full-race tune and using over 5000 rpm most of the time, although I doubt it is the cause of your bottom end running issue.
Posted 11 November 2020 - 08:41 AM
Posted 11 November 2020 - 09:13 AM
I would bin the carb. And as mentioned you will need to pass the injection emissions level at the MOT.
not to mention it will need the cat fitted for the MOT.
Edited by nicklouse, 11 November 2020 - 09:19 AM.
Posted 11 November 2020 - 10:21 AM
Posted 11 November 2020 - 07:43 PM
Posted 11 November 2020 - 10:33 PM
But id also suggest sending the new dizzy to be recurved and rebuilt.
Check for air leaks on the manifold gaskets including the carb abutment plate gaskets
Edited by cal844, 11 November 2020 - 10:34 PM.
Posted 11 November 2020 - 10:51 PM
Posted 11 November 2020 - 11:13 PM
65D is the electronic dizzy that came on the 1990 onwards cars that didn't have injection. I have them on 2 earlier minis, a 1980 estate and a 1989 Mayfair. I also have a 1275 sprite with the same set up. All run perfectly well with no issues.That’s great cheers mate I’ll have a look into possibly purchasing a 65D dizzy then. Sure I’ll have a look around for any air leaks tomorrow cheers, seems to be loads of little pieces on the Nikki carbs where air could get in
My opinion is to get rid of the Nikki carb and use an SU, either an HIF 38 which will best suit your spec for more torque
Edited by cal844, 11 November 2020 - 11:14 PM.
Posted 11 November 2020 - 11:37 PM
That’s what I’m thinking to be honest, Nikki carbs look wicked and the idea of the twin choke opening at higher rpm sounded cool but think their more effort than their worth especially with the lack of spare parts. Will have to run the Nikki carb for a while as I’m only 17 and out of a job due to COVID ? I’ll see how well I can get it running and probably eventually switch out the carb
