My MG Metro has been having some very rough cold starts this year, to the point where it sounds like it’s running on 1 or 2 cylinders and if I can keep it alive with full choke and throttle eventually you can hear all the cylinders come on and once warm it runs lovely.
I whipped the plugs out and found cylinder 2 and 3 had wet tips and assumed this was coolant.
Penny now dropping...
I had been getting random coolant leaks last few months, mainly after the car was parked and cooling down, a jubilee clip here, another there, then the heater matrix seals and so forth.
Now, about 5k miles ago I, following many forum posts, youtube videos, Rover workshop manual and carried out the headgasket change as the original had blown across 2/3.
I’m now thinking that the cooling system is being pressurised by exhaust gases and coolant entering 2 and 3.
Now, as an A series novice, I used the Payen BK450 gasket as recommended and wondering if it is really likely to have failed, or did I really do something wrong?
I know it is/ was a good strong engine until this issue as a totally stock MG engine was making more than factory power, admittedly with refurbed carb, Manflow exhaust and Shell Vpower, but still.
I got a Norton oil stone with lube and made sure the block and head mating surfaces were perfectly flat with no pieces of old gasket and I’m just a bit puzzled
Edited by traineecollins, 12 November 2020 - 08:54 PM.
