Did you change the whole thing or rebuild kit?As I said previously I had the same issue and replacing the master cylinder cured this. As there are no leaks anywhere is change the cylinder
I just changed they cylinder as its quicker than rebuilding. By the time you rebuild then refit the cylinder and bleed the brakes you could be on the road.
