Sykes-Pickavant Acr4 Handset
Posted 16 November 2020 - 06:14 PM
Car is a 1997 Cooper mpi
Posted 16 November 2020 - 08:23 PM
I’ll look , pretty sure I have the original documents for these.
Which pod do you have for it?
Make sure the the pod is firmly plugged into the base of the ACR4 and do not remove.
Make sure that the lead is plugged into the correct port at the top (should have a pic of a car)
If it’s a U.K. market car then plug into the port next to the heater on the drivers side.
For setting the IACV on MPi the engine must be at full operating temperature (thermostat opened and hot) before you attempt it.
The sequence is to go to the Menu For the car Rover -> Engine -> Petrol (can’t remember the exact sequence but step down through and there is one called Service Reset.
After this you need to ESC back to the menu and then go MEMS2J.
I’ll see if I can find the exact sequence for you but the IACV is aka the stepper and the Software tunes it showing a line of boxes across the screen (sometimes depending the version of software it shows the number of steps)
it’s in the -> component -> actuator menu from memory
FS
Edited by FlyingScot, 16 November 2020 - 08:41 PM.
Posted 16 November 2020 - 08:31 PM
Don’t unplug anything when the ignition is on (or the motor running).
Basically connect and disconnect only with the ignition off.
FS
Edited by FlyingScot, 16 November 2020 - 08:42 PM.
Posted 16 November 2020 - 08:40 PM
96C7EA50-64CB-44B5-BE5B-11781C206B5A.jpeg 51.55K
14 downloads
I’ll see if I can find them electronically as they used to be on SP Diagnostics support site (now no longer)
FS
Edited by FlyingScot, 16 November 2020 - 08:44 PM.
Posted 17 November 2020 - 05:17 PM
FS
Hi thanks for taking the time to look into this for me it’s appreciated ?
The pod I have is Rover V3 30350800
I’ve plugged the pod into the unit this bit I figured out
I’m yet to get upto the car to see if it’ll connect but once I do I’ll report back thanks again
Posted 17 November 2020 - 07:11 PM
FS
Posted 18 November 2020 - 02:56 AM
Sorry I was trying to make a video on the ACR and did not check in.
http://www.tmsmini.c...r_mg_pod_3a.pdf
Hopefully have a video at some point.
This is for Rover Pod 3
Posted 18 November 2020 - 07:35 AM
Honestly! that’s brilliant thank you mate really appreciate it
King regards Lee
