Jack Knight Transfer Gears
6 replies to this topic
#1 1963MKI
1963MKI
  • 163 posts
Posted 20 November 2020 - 03:45 PM
Ive got a set of 1.08 transfer gears and I think I may be missing some parts. I got them in a job lot of spares.
I think i'm missing some bits and I have some general questions.
There was supposed to be some sort of through bolt with a flange that hold its all together but i seem to be missing that. There is also a small ring that appears to fit between the two roller bearings, but when you put that in the centre of the assembly it stops you applying any preload as it stops the two bearing being pressed together. Im not sure of the purpose of this, or have I got it set up wrong ?
Does anyone have any information on the missing parts or how to set these gears up ?
#2 Spider
  • 15,850 posts
Posted 20 November 2020 - 06:12 PM
Most of it looks to be there, it is missing the End Washer and Bolt though.
The parts fit over the shaft as you have them laid out, over the Shaft it's :- Bearing, Spacer, Idler Gear, Bearing, Collar, End Washer and then Bolt.
The Spacer is as you have surmised, to apply the correct pre-load to the Bearings so they can't be over tightened, much in the same way as our Front Wheel Bearing assembly.
Fitted in the the Gearbox, the Bolt goes in to the Gearbox side, but you need to be sure it doesn't poke through the Idler Gear (Bearing) hole in to the inside of the Casing, as the Web of the Crank swings around past that. It can poke out a little, but check there is clearance to the Crank Web - I'd suggest a minimum of 0.030" here.
The Bolt is an Inhex Cap Head from memory.
#3 1963MKI
1963MKI
  • 163 posts
Posted 20 November 2020 - 06:24 PM
okay, but with the spacer between the bearing, I can not get any pre load at all. The gear just rattles around on the bearings, so im stumped ?
#4 stoneface
stoneface
  • 430 posts
Posted 20 November 2020 - 08:18 PM
I have these photos I down loaded from eBay some time ago. So not mine but shows something very simillar to yours.
It does look like you might be missing the part that goes in the gearbox with the threaded hole for the bolt. First 2 photos.
Attached File  12A1288-3-Sync-Straight-Cut-001.jpg   58.59K   1 downloadsAttached File  12A1288-3-Sync-Straight-Cut-002.jpg   76.72K   1 downloads
Attached File  12A1288-3-Sync-Straight-Cut-003.jpg   48.49K   2 downloadsAttached File  12A1288-3-Sync-Straight-Cut-004.jpg   45.87K   1 downloads
#5 Spider
  • 15,850 posts
Posted 20 November 2020 - 11:57 PM
They did have several incarnations of these, I suspect yours maybe earlier than the one I had.
The Washer * maybe * a side spacer fitted between the Gearbox Case and the Bearing on that side. I'm not sure then how you maintain the pre-load, I guess it must just be on the bolt with some thread locker ?
#6 1963MKI
1963MKI
  • 163 posts
Posted 27 November 2020 - 07:45 PM
yes im starting to think it might be a spacer that goes on one side of the bearing. Ill have to try and mock it up and see.
#7 1963MKI
1963MKI
  • 163 posts
Posted 27 November 2020 - 07:46 PM
Thats a great help thanks you. I can kind of see what im missing now. I do have a screw cutting lathe at home so its not beyond the realms of possibility to manufacture the missing part.
attachicon.gif 12A1288-3-Sync-Straight-Cut-001.jpgattachicon.gif 12A1288-3-Sync-Straight-Cut-002.jpg
attachicon.gif 12A1288-3-Sync-Straight-Cut-003.jpgattachicon.gif 12A1288-3-Sync-Straight-Cut-004.jpg
