Problems Dropping Into 3Rd Gear
4 replies to this topic
#1 BEN99W
BEN99W
  • Just Joined
  • 60 posts
Posted 26 November 2020 - 12:30 PM
Hi
We've not long bought an early mk3 mini 850. which originally had a magic wand shift but has at some point been changed to a later remote gearchange. Im still trying to assess exactly what we've got, but one issue which has reared its head is a difficulty going from 4th to 3rd gear. It will go from 2nd to 3rd fine, but crunches unless double declutched coming down to 3rd.
Is this likely to be a knackered synchromesh, or are there other possible causes like bushes that might cause similar?
And how easy are such problems to fix?
Many thanks
Ben
#2 KTS
KTS
  • 2,490 posts
Posted 26 November 2020 - 02:28 PM
from the symptoms i'd agree, most likely worn synchromesh
to fix requires separating the gearbox from the block, so obviously an engine out job
how easy/difficult is a bit subjective as it depends on your level of competence (and to an extent having the right workshop equipment), but should be well within the capabilities of most competent enthusiasts
#3 MrBounce
MrBounce
  • 2,686 posts
Posted 26 November 2020 - 03:18 PM
I would agree with KTS - unless it graunches in other gears in which case it might be clutch drag. Sounds very like the issue I had on my old GT (which I never fixed...)
#4 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 26 November 2020 - 03:34 PM
They called these gearboxes remote, because there was a remote chance you would find the gear you were looking for..I would check the linkage first, as its quite convoluted on a remote box, make sure its all working as expected, its unusual for a syncro to go on 3rd before shagging 2nd first... not impossible though esp if its been hammered (ie revved the granny out of) in 3rd with someone holding the gear lever in 3rd gear ....
#5 BEN99W
BEN99W
  • Just Joined
  • 60 posts
Posted 27 November 2020 - 01:33 PM
Thanks for the responses chaps.
Ill take a closer look at the remote linkage. Is there a possibility that 3rd gear might be easier to find if I converted it back to a magic wand type gearchange (providing of course that synchro hasnt gone)?
Otherwise, if it does turn out to be a worn synchro, Ill have to see what getting the engine out involves and what other jobs Im likely to want to do while it is out.
Ben
