Hello all.
I have a cooper 1.3i which has 4 spotlights on the front grill. The outer two spotlights are fog lamps (and these have their own rocker switch to control them near the driving wheel) and the inner two spotlights are driving lamps and they are connected to my full beams circuit. I have just had the main wiring loom worked on and it has been wired up differently to what I had before and I'd just like to check which is the correct way to have it as I keep getting told different things. Here are the details (I hope it makes sense). Please can anyone with 4 spotlights let me know how they have theirs set up or how they should be. Many thanks all!
Previously: When the headlights were on I could also turn on the fog lamps, but when I used my full beams the fogs would turn off. So at no point could all four spotlights be on at the same time.
Now: When the headlights are on I can turn on my full beams, and only then can I turn on/off my fog lamps also - at the same time - so all four spotlights can be on at the same time. But I can only use my front fogs when the full beams are on.
Feedback much appreciated!! <3
