Srs Light And Oil Pressure Light
Best Answer leepol83 , 29 November 2020 - 01:43 PM
Got this sorted turns out the led bulbs are popularity correct 🤷♂️😂 turned the bulb round and sorted thanks for the help Go to the full post
Posted 27 November 2020 - 07:00 PM
In the car and just checking it all works, is there a way to just Check the srs light is working and also the oil pressure light ?
Thanks 😊
Posted 27 November 2020 - 07:46 PM
Turn the key to 'On' both lights should light. The SRS will go through its checks and, if everything is ticketty-boo, the SRS light will go out. The oil light should still be on. Now start the engine the oil light should go out within seconds, if it doesn't go out within twenty seconds, turn engine off before causing catastrophic damage and investigate. If all is well, and the oil light goes out, drive the car until it's up to temperature, turn off to stop engine and quickly turn back to 'On'. oil light will, probably, be out but will come back on within a few seconds.
Check complete.
Edited by Quinlan minor, 27 November 2020 - 08:13 PM.
Posted 27 November 2020 - 07:59 PM
Okedokey need to look into that then, wasn’t sure if there was a way to force them on to check but sounds like they should be on with ignition, I’ve changed all the bulbs to led so maybe in the wrong way 😬Turn the key to 'On' both lights should light. The SRS will go through its checks and, if everything is ticketty-boo, the SRS light will go out. The oil light should still be on. Now start the engine the oil light should go out within seconds, if it doesn't go out within twenty seconds, turn engine off before causing catastrophic damage and investigate. If all is well, and the oil light goes out, drive the car until it's up to temperature, turn off to stop engine and quickly turn back to 'On'. oil light will, probably be out but will come back on within a few seconds.
Check complete.
Posted 28 November 2020 - 11:32 AM
Posted 28 November 2020 - 04:57 PM
Nope left that one 👍🏻Hope you haven't changed the battery light for led...
Posted 29 November 2020 - 01:43 PM Best Answer
