Upper Arm Repair Kits
6 replies to this topic
#1 mattrsa
mattrsa
  • 120 posts
Posted 30 November 2020 - 02:07 PM
Hi All
In the progress of building up a spare subframe with all the suspension components. I have removed the upper arms from the car and see that there are repair kits sold for them? My questions is how do I establish if I need to repair them, or should it simply be a case of getting the kit and fitting as a matter of procedure since the arms are removed. I obviously don't want to be forking out money for the kits if It is not required.
Thanks in advance
Matt
#2 nicklouse
  • 18,709 posts
Posted 30 November 2020 - 02:27 PM
Have a look at the axle and feel for play.
#3 RooBoonix
RooBoonix
  • 1,225 posts
Posted 30 November 2020 - 03:27 PM
Pull the pin out and see if it's worn. When I removed mine the pins were rusty and has indentations/wear from needle rollers which hadn't been rolling.. if you pull the pins out and they have nice clean grease and they turn smoothly with no play then you should be fine.
#4 Spider
  • 15,174 posts
Posted 30 November 2020 - 06:28 PM
If buying a new kit, check the bearings that are supplied with it, there's some cruddy ones getting about, usually marked KOR.
#5 RooBoonix
RooBoonix
  • 1,225 posts
Posted 01 December 2020 - 11:04 AM
I've got some kits in stock for my car, I'll check them out. What is wrong with the bearings out of interest?
Cameron
#6 Spider
  • 15,174 posts
Posted 01 December 2020 - 07:13 PM
Cameron
Hi Cam !
There's been a few posts on the forum about them. This one has a few links to some of the others;-
https://www.theminif...rbox-questions/
#7 RooBoonix
RooBoonix
  • 1,225 posts
Posted 01 December 2020 - 07:54 PM
Cameron
Hi Cam !
Thanks Chris, should have thought to do a search... Cheers
