How Does The Verto Flywheel Nut Washer Tab Work?
3 replies to this topic
#1 babsbrown
babsbrown
  • 521 posts
Posted 01 December 2020 - 08:57 PM
Evening everyone, I'm just intrigued as to how the verto locktab actually works. I'm presuming the tabs are knocked into the slots in the keyed washer that sits behind the flywheel bolt. But how does that exactly prevent the bolt from loosening? Unlike the ball joints lock tab that fits around the points of the nut, it doesn't appear to actually make contact with the bolt. Thanks in advance, Luke
#2 cal844
cal844
  • 9,649 posts
  • Local Club: TFMOC
Posted 01 December 2020 - 09:17 PM
When you've torqued the bolt up the tab is bent outwards (I use a blunt masonry chisel for this) into the slot in the centre boss just to keep everything locked in.
#3 GraemeC
GraemeC
  • 7,440 posts
Posted 01 December 2020 - 09:25 PM
The lock tab is spot welded to the flywheel bolt.
#4 babsbrown
babsbrown
  • 521 posts
Posted 01 December 2020 - 09:53 PM
Got ya!! Cheers fellas! That cleared that right up!
