Hi Rob
I don’t have any figures on the charge temps probably something I should do at some stage
My main reason for fitting was for a bit of safety and because its a suck through setup with no intercooler
I run 12psi @ 8.5 comp ratio and timing is set fairly safe
128 hp and 129 ft-lb at the wheels
On track even when 30 degrees Celsius I can hammer around with no issues
My tank is 3.7 litres and depends on settings and use for how long it lasts
Road use I set to start injecting at 5 psi. The water will last longer than a tank of gas if driving normally
On track I set it to start at 2 psi and have to top up after about 15 laps which is approx 50 km
Dan
I run the Aem kit on my supercharged mini
Injecting after charger
It’s a progressive controller so the more boost the more water
Add a solenoid into the line close to the injector and then there is no issue with siphon and can mount tank any height
Just had a read through your build. Looks really nice.
How well does the water cooling perform?
Do you have any statistics on charge temps before and after fitting the kit?
Biggest question - how many litres of water do you have and how long does it last compared to fuel?
Rob
