Bosch Universal Lambda Sensor
5 replies to this topic
#1 tmsmini
tmsmini
  • 733 posts
  • Local Club: MOASF
Posted 04 December 2020 - 04:07 AM
Has anyone used one of the Bosch universal lambda sensors?
I used the one listed as 15730 in the US. It did not work.
The code on the sensor is 0258986507.
I cannot get the Bosch UK site to work for me to identify the correct version.
Anyone have a Bosch part number?
https://www.boschaft...97#scrolldetail
The website asks one to add a vehicle, but I see no way to do that in either Chrome or Firefox.
Terry
Edited by tmsmini, 04 December 2020 - 04:09 AM.
#2 genpop
genpop
  • 527 posts
Posted 04 December 2020 - 07:01 AM
This is the right one : https://www.amazon.d...e/dp/B0049PK2K0
#3 tmsmini
tmsmini
  • 733 posts
  • Local Club: MOASF
Posted 05 December 2020 - 07:47 PM
This is what I got back from Bosch USA:
There are no direct cross numbers to a universal for the number you gave, the type of sensor that you gave me is an LSH-6, I did find one in that type that is universal and an LSH-6 type and is in stock.  The part number is 0258986503.
The marketing number is 15736, the tip might look different but should work the same. If this is for a vehicle application call us at the number below and we can see it there are any universals for the application.
Best regards,
Bosch AA
Being the US, I was looking for an easily available solution. The US suppliers sell the MHK10004 replacement at a premium. Often time they say they are Bosch, but are unmarked.
I was unaware that there are several early types of narrow band.
I will order a spare in the future as Somerford has them for £39.99 Ex VAT.
I may try the 15736 at some point, not sure what the marketing number is for the UK.
#4 genpop
genpop
  • 527 posts
Posted 06 December 2020 - 07:25 AM
I fear the somerford ones will not work as well.
#5 tmsmini
tmsmini
  • 733 posts
  • Local Club: MOASF
Posted 06 December 2020 - 04:04 PM
I did not mention that tis engine is an MPi, but the lambda sensor is the same., SPi or MPi.
I had a used one that I had run with a SC controlled engine for a few hundred miles before switching to a wide band in that car. It seems to be working.
As there in no easy way to test outside of the engine, it can be expensive to buy and try...
#6 genpop
genpop
  • 527 posts
Posted 06 December 2020 - 06:35 PM
On MPI the universal ones should work!
