Metro 998 Compression Ratio Conundrum
11 replies to this topic
#1 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 December 2020 - 10:15 AM
Hi all,
I currently have a 998cc Metro with what I believe is the high compression engine, quoted at being 10.3:1.
However, using my compression ratio calculator ( https://jscalc.io/ca...RNEglVkKLQir11T ) with 64.58mm pistons, a 76.2mm stroke crank, 2.8cc head gasket, flat top pistons, 25.5cc in a CAM4810 head and the pistons level with block deck height I still only get around 9.72:1
Anyone know what makes up the difference?
Page 28 of this document...
http://metroownerscl...-1984_24_41.pdf
...states: "MODIFICATIONS TO THE PISTON HEAD REDUCED THE SIZE OF THE COMBUSTION CHAMBER"
Any ideas?
#2 nicklouse
  • 18,696 posts
Posted 04 December 2020 - 10:37 AM
What is the engine number?
#3 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 04 December 2020 - 10:47 AM
99H A08P 100235
#4 nicklouse
  • 18,696 posts
Posted 04 December 2020 - 12:02 PM
I would go back to basics and work it out. There may be something wrong in that calculator.
I agree with your assumption of it being a high compression build from that engine number.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 04 December 2020 - 12:25 PM
That’s what you usually get, but you must actually measure your components are they do vary. This high ratio is usually achieved by smaller chamber volume either in the head or deck volume.
Ac
#6 GraemeC
GraemeC
  • 7,440 posts
I wonder if the 'marketing speak' of MODIFICATIONS TO THE PISTON HEAD REDUCED THE SIZE OF THE COMBUSTION CHAMBER actually means the head was skimmed, bringing the chamber volume down?
Otherwise it would have to be piston tops out of the bore or raised crowns
Edited by GraemeC, 04 December 2020 - 12:27 PM.
#7 Cooperman
  • 23,326 posts
Posted 04 December 2020 - 05:07 PM
Yes, you will recall that the 998 Coopers had raised D-Top pistons to increase the CR.
#8 Spider
  • 15,136 posts
Posted 04 December 2020 - 07:58 PM
The internet is a wash with these Calculators for all manner of things. Those I've looked at and checked by old school means have never been right.
#9 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 04 December 2020 - 08:37 PM
For anybody not familiar with what’s involved in calculating static compression ratio, I made a video for my YouTube channel explaining it,
Super simple!
Phil.
Edited by Turbo Phil, 04 December 2020 - 08:40 PM.
#10 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 14 June 2021 - 07:18 AM
Just to answer my own question for anyone else searching for this answer:
When I took my cylinder head off recently and took some measurements it looks like they skimmed off 40 thou at the factory to increase the compression ratio to the quoted 10.3:1.
This would take the normal CAM4810 head chamber volumes from 25.5cc to roughly around 23cc.
#11 Steam
Steam
  • 821 posts
  • Local Club: Victorian Mini Club
Posted 16 June 2021 - 10:26 PM
Have you tried this.
https://www.theminif...tio-calculator/
#12 podifold
podifold
    Suck through sucks
  • 376 posts
Posted 17 June 2021 - 06:52 AM
Yes. I wrote it.
