Hi Mini-mates,
I have spend the past three months figuring out where to find the right rings for my pistons.
I've come to the conclusion that the pistons that I have is one of a kind (+/- 2).
Engine information:
No engine plate
A+ type 998cc
Bore size 65,33mm / 2.572", indicating that it's a 1022cc (0.030 oversize).
Stroke 76,34mm
The identification and information on the pistons are as follows:
Flat top, four ring, circlip type pistons.
TRW 175-9798T (found on the inside of the piston)
21 6-8406 (also found on the inside of the piston)
+.03 (found on top of piston) which indicates that it's a 0.030 oversize, I guess.
Front JGO 06 (also found on the top of the piston).
ø65.28 (also found on top of piston). I guess this indicates what bore size it's prepared for, as the diameter of the piston is 64.73mm (measured above the top ring)
Compression height approximately 33,84mm
1st groove width (top): 1,69mm ; depth approximately 3,07mm
2nd groove width: 1,69mm ; depth approximately 3,07mm
3rd groove width: 1,69mm ; depth approximately 3,07mm
Oil ring groove width: 4,04mm ; depth approximately 3,45mm
The ring that was fitted to the pistons upon disassembly has the following information:
1st ring thickness 1,56mm ; width/depth approximately 2,74mm ; square type with bevel on inside/top.
2nd ring thickness 1,59mm : width/depth approximately 2,82mm ; square type ring.
3rd ring identical to 2nd ring.
Oil ring thickness 3,93mm ; width/depth approximately 2,42mm ; coil spring loaded beveled oil control ring. I think it's called the GS type.
Now I have to decide whether to continue looking for a set of rings or go for a replacement of the pistons.
So far I've found Deves R33636-030 which comes close. It's multipiece oil ring (0.158") with two rails, one spiral spacer and an inner spring.
All help is appreciated as I'm very close to giving up.
Stefan
