Connecting Rod Size Question
7 replies to this topic
#1 TehMarchant
TehMarchant
  • 628 posts
Posted 04 December 2020 - 07:40 PM
Hi all,
I am gathering parts for an engine build.
I was just curious if these rods are the right size.
Dimensions
Center to center length: 146.05mm
Big end diameter: 45mm
Small end diameter: 20.63mm
Sorry they supply the measurements in MM
I’m using p21253 pistons, which are interference fit
Cheers all
#2 mini13
mini13
  • 3,811 posts
Posted 04 December 2020 - 07:55 PM
what are you putting them in?
those dimensions look to be for a 1275 rod,
#3 TehMarchant
TehMarchant
  • 628 posts
Posted 04 December 2020 - 07:57 PM
Sorry should have specified. It’s a 1275 a+ Mostly concerned about the wrist pin size
#4 mini13
mini13
  • 3,811 posts
Posted 04 December 2020 - 08:03 PM
ok you should be good then,
the wrist pins are IIRC 812 thou (0.812inches or 20.625mm)  are these normal rods or somthing aftermarket? ie not press fit pins.
#5 TehMarchant
TehMarchant
  • 628 posts
Posted 04 December 2020 - 08:14 PM
You e been so helpful, Yes they’re aftermarket
https://www.ebay.co....4.m46890.l49292
Hoping they’re lighter than standard and should take abuse better
#6 nicklouse
  • 18,767 posts
Posted 04 December 2020 - 08:32 PM
Mmm don’t look like they will work with your pistons of choice. As they seem to have a bush fitted.
#7 TehMarchant
TehMarchant
  • 628 posts
Posted 04 December 2020 - 08:34 PM
That’s kinda what confused me about their image. Could just be a generic image though
#8 mini13
mini13
  • 3,811 posts
Posted 05 December 2020 - 03:10 PM
Ah!
yeah they will be sliding fit, also I did heas somthing about the web being larg enough to contact the bottom of the  bore especially on standard bores.
I have used sliding fit rods before ( also converted std rods with a reamer to sliding fit to maks assy/disassy easier) with PTFE pin buttons ( auminium has also been done), bit you'd have to get those made up specifically to your pins as the pins vary between piston manufacturer.
I will say although H beam rods are nice, they really arnt needed, the standard rods are very robust, and jsut swapping to arp rod bolts would give a pretty bullet proof bottom end.
