Hello
1993 L reg SPI Cooper
I am removing and replacing my radius arms
Only one side so far
I've got almost everything loose, undone and disconnected
No snapped / sheared anything
Not yet anyway
But there's one bolt I can't get to
Of the 4 bolts that hold the radius arm in place at the wheel arch end
The two vertical bolts that connect the radius arm into the bracket were fine. Both out.
There are then a further 2 bolts that sit horizontally, one above and one below the radius arm.
The top one came out without a hitch
Getting to the point...
I can't get to the bottom of these two bolts
It's a half inch bolt head
But the space between the radius arm and the bracket is too small to get a half inch socket onto the bolt head
I've watched a few youtube videos of people doing this job and nobody seem to have had the same problem
Anyone had the same problem?
Any tips for getting over / around it?
Elwyn
