Complete Sill Replacement From A Donor?
Posted 09 December 2020 - 10:08 AM
What I'm wondering is, I have access to a donor shell with believe it or not very good sills and floor, is it possible to trim and seam weld in the entire section in one piece rather than fitting up and welding together all the individual repair panels? Or should I just bite the bullet and buy all the individual new parts?
Posted 09 December 2020 - 10:29 AM
I cant see why that wouldnt work.
Might make jiggling and minor adjustments harder.
Posted 09 December 2020 - 10:35 AM
It would work, but sills are often one of the first areas to rot on a Mini so unless the donor shell is in very good condition it's best avoided. It would make me question why it's a donor shell and unless money really is a restricting issue, I'd buy new. It's a lot of work to fit something that's already on it's way to needing replacement.
Posted 09 December 2020 - 11:34 AM
Keep in mind you can't see how good the sills are on the donor car within the sill cavity - they generally rot from the inside.
Edited by GraemeC, 09 December 2020 - 11:35 AM.
Posted 09 December 2020 - 12:20 PM
My opinion would be similar to what has been said
Yes it can be done but it's a lot of work and I cant really see what savings would be made as the replacement panels are already very cheap.
I would bet money that there will be significant corrosion within the sill cavity and probably in the jacking point and heelboard.
My biggest issue would be how are you going to cleanly and neatly remove the donor panels to reuse?
The very way a mini is constructed would mean that any slight damage to the join seams of the panels will mean they would need trimming back and rebuilding before you could fit them. All joints would need to be staggered especially if you are grafting over the end of the seat cross member too.
I wouldn't bother
Ben
Posted 09 December 2020 - 12:55 PM
Do it right once...
Posted 09 December 2020 - 12:58 PM
I would also agree with the guys above, go new unless you can see inside the donor sills.
A couple of other points.
1) Does the donor have proper vented sills? If it has non-vented over sills that's probably why they look good, behind that is likely a different story.
2) If this is for your Elf it will, as far as I know it should have a 4 flute sill, which may be different to the donor. Obviously this depends on your view on originality.
Being where you are may sway your thoughts depending on part availability.
Posted 09 December 2020 - 02:07 PM
Posted 09 December 2020 - 05:12 PM
Now outer sills are cheap and the M a machine ones are very good value for their money. Doorsteps, well they are a con with regards to the heritage item as you cannot just get the step section. You get A and B pillar as well. Which is fine if you need them but if not then a waste.
Magnum doorsteps I advise like the plague, just bloody awful.
Posted 09 December 2020 - 09:54 PM
Posted 09 December 2020 - 10:00 PM
Well I guess the jury has voted unanimous on that idea . At this point I am just in the research phase before I commit to doing anything. But in answer to a few questions above, yes it is for the Elf, I am not too fussed about originality owing to how uncommon the parts are I realize some bits will be a compromise of the easiest to get parts. I am in New Zealand, but fortunately only about a 40min drive from the countries biggest specialist which stocks most of MiniSpares catalogue including repair panels so will have to have a look at what's available. The 'beam' visible in the bottom of the companion bins is part of the inner sill correct?
Its called the Companion bin closeout / inner sill stiffener depending on who you talk to.It ties in the inner sill to the bottom of the B pillar and the rear arch closeout.
Posted 09 December 2020 - 10:01 PM
Somerford mini website (Heritage panels) https://www.somerfor...abriolet-100736
11 14A8994 STIFFENER, inner sill, RH 1 Includes later specification piercing. 14A8995 STIFFENER, inner sill, LH
Posted 09 December 2020 - 10:14 PM
The only reason I was considering the donor vehicle is having looked at the condition of it I would guess its had the floorpan and sills replaced at some point shortly before it was taken off the road or someone had started replacing as a project. Reason being the roof is completely gone, the A and C pillars are virtually disintegrated where they attach to the roof frame (owing to gutters rusted through) and for that much water to be getting inside the pillars without a spot of rust on the floors and sills would be otherwise strange. All bottom panels look correct and clean and not oversills and not a trace of rust in the usual first sign places like panel joins and where the little brackets that hold the carpet edges are welded to the angled part of floor
Posted 10 December 2020 - 08:23 AM
Might be worth sticking some photos of inside the car and underneath on here, you'll soon get a decent answer
Posted 10 December 2020 - 09:05 AM
