changed my mini from 12" to 10" wheels and now id is flat out at 70 mph will I have to change the diff if so what ratio?
I Changed My Mini From 12" To 10" Wheels
Posted 14 December 2020 - 11:19 PM
Posted 14 December 2020 - 11:27 PM
Err it will not be as the actual wheel size is about the same. Your Speedo may be reading incorrectly though.
Posted 14 December 2020 - 11:48 PM
There is usually a very small difference in the rolling diameter between 10's and 12's on a Mini.
Are you getting that speed indication off your speedo or a GPS ?
Can you also tell us a bit more about your Mini, what engine size, what's been done to it, final drive ratio (if you know it) etc?
Posted 15 December 2020 - 08:21 AM
Mine went from 12"s to 10"s and it made no difference to the top speed.
The comfort, handling and roadholding were, however, massively improved, as were the looks.
Posted 15 December 2020 - 08:55 AM
Probably because it made the car soooo much better and the back roads were calling all the time...
Even once took me 3 hours to get to the local shop for milk... ooops..
Mins are either faster off the line or faster on top end.. canna really have both...
Check the GPS speed..
Posted 15 December 2020 - 10:02 PM
I just did the maths and the difference is 0.33 ins on a rolling radius of 9.87" for a 12" and 9.54" for a 10". This is around 3% difference which is about the useable tread depth.
Edited by Cooperman, 15 December 2020 - 10:06 PM.
Posted 15 December 2020 - 10:08 PM
Here is some good info
Fluf
