Hi everyone,
Wanting some opinions or experience from anyone who has had this sort of spec engine using twin HS4 carbs and what needles you have used/started with. In the process of getting my mini back on the road after years of it sitting. I have purchased twin hs4s with stub stacks and K&N filters to upgrade my twin hs2s. below is the spec,
1310cc, Block drilled for 11studs, 1.5 roller rockers, Piper 285/2 cam + modified head ported and polished to suit 285/2 cam, S/S race valves inlet 1.401 (35.6/29), aldon yellow, maniflow st2 LCB single box, NGK BP7RES plugs.
thank you
Edited by mvahora, 16 December 2020 - 01:16 AM.
