Edited by John/Dominguez, 17 December 2020 - 12:18 PM.
Posted 17 December 2020 - 12:11 PM
Posted 17 December 2020 - 03:23 PM
So you have uploaded 3 pictures. 2 are not for a Mini or may be but with a pipe not mounted in the correct orientation.. The other is.
But you might not find a exhaust pipe that will work with it as most manifolds continue under the car before attaching to the exhaust system.
Edited by nicklouse, 17 December 2020 - 03:24 PM.
Posted 17 December 2020 - 05:54 PM
The lower part of the Speedwell Manifold appears to be a separate section that can be turned 90 degrees to fit in a Mini. We have a locally made manifold which is similar.
I think the difference in performance between the Speedwell item and the original Cooper item would be in academic numbers, but given the way the Speedwell item is made, I feel it would last longer.
Posted 18 December 2020 - 11:11 PM
Posted 19 December 2020 - 10:11 PM
The difference in performance is likely to be measured in tenths-of-a-second per lap. On the road you'll not notice any difference. Very few drivers can tell the difference between 0 - 60 in 12 seconds or 13 seconds.
Posted 23 December 2020 - 05:43 PM
Posted 23 December 2020 - 09:45 PM
Posted 23 December 2020 - 09:52 PM
Edited by cal844, 23 December 2020 - 09:53 PM.
