I upgraded from drums to discs recently using this kit from Minispares. No servo is fitted and without the self servo effect of the drum brakes higher pressure is required on the brake pedal but not too much, I like the solid feel of the pedal and the brakes feel so much more progressive than the drums.
Now with drums I've found that if you try stopping really quickly from 75 ish you have almost no braking left by about 40 due to heat build up but they come back quite quickly so next time you need them they're there again. I decided to test the discs from a similar speed by braking proper hard and they were certainly very capable of slowing the vehicle down - I'd say quicker than with drums but at the next roundabout say half a mile away I had a very solid pedal but very little braking. This continued for quite a few miles afterwards and was rather disconcerting as I changed to discs to improve brake fade not make it worse.
Once the brakes had cooled properly they worked fine again but it's shaken my confidence in them a little. In general use they are fine, even when braking quite hard but a few genuine hard stops on the motorway could be interesting.
Any ideas what's going on here as other people don't seem to report this issue?
