I have read the Headline Fitting Instructions in the FAQ, but am not convinced I am doing things correctly as mu headlining still appears a bit loose. As a result I have not yet started to glue the headliner.
C59EFB14-E963-47C6-96A1-60E8E3D8DEAA.jpeg 63.56K
3 downloads
F35985C2-BE3C-4ABC-8907-2678A0744AFA.jpeg 50.03K
5 downloads
1AEA9A59-3E64-4C9A-A1F3-E8F37ADE8B38.jpeg 44.49K
2 downloads
C5DEDCED-5826-40C0-A4C6-7438A708A643.jpeg 43.26K
1 downloads
I have fitted headlinings in the past to Ford Escorts, Chrysler Avengers & Sunbeams and had no problems with them, if I recall they had a bit more stretch in them.
As you can see from the photos it appears that the fabric is a tad loose between the rails.
is there anyway the headliner can be shrunk after gluing to tighten and take up the slack and remove the creases?
or am I doing something fundamentally incorrect?
