Help With 998 Road Engine Specification
9 replies to this topic
#1 HazleNut21
HazleNut21
  • 15 posts
Posted 19 December 2020 - 06:15 PM
Hi All,
Calling on the collective wisdom of those with more know-how than me. I've decided to keep the original 998 engine that came with the car I am restoring, but want to give it a little more pep for "spirited" road driving. The car will mainly be used as an enjoyable weekend toy, I am aware it's not going to be "fast" by modern standards but just something that has enough oomph to enjoy around country roads.
I understand that there are sooooo many options with engine building for the A series and after spending far too long reading forum posts about all the different pathways I have finally come to the conclusion that its best just to ask my own questions.
So my initial thoughts at piecing something together,
998 +60thou (flat top pistons)
Bottom end balanced
CST2004/05 head
SW05-07 Cam
1.3 ratio rockers
Stage one kit, exhaust
What would I need in terms of fueling and ignition? I would like to go electronic ignition, what kind of dizzy carb/needle should I be looking at etc etc. Should I also be aiming for around 10:1 comp?
Open to suggestions as relatively new to this stuff :)
#2 Dusky
Dusky
  • 5,322 posts
Posted 19 December 2020 - 06:36 PM
Sounds like a very good setup. I would add a lightened pre verto flywheel. Really brings engines to life.
#3 humph
humph
    How bad can it Be?
  • 1,101 posts
Posted 19 December 2020 - 09:02 PM
Sounds like a good spec.
I’ve just had this one Built by Jim @ r.a.c.e engineering;
998cc A+ block - Bored to 0.060" & skimmed to to get a C.R of 10.5:1
Crank - 998cc Re-ground
Head - 12G295 skimmed by 0.050"
Pistons - P-22463 +0.060" Flat Top
Cam - Minispares Evolution001 - recommended by many and cheaper than most.
Timing chain - 3H2127EVO timing chain (simplex)
Final Drive - 3.44
HIF38 Carb
RC40 exhaust
K&N filter in a modded original airbox
Being as it's a road car I was advised against a lightened flywheel, but we'll see how it goes when he's up and running. Seems there’s plenty of differing opinions on this.
Frustrating thing is it'll be next summer (at the earliest) before I'll be able to try it.
#4 Cooperman
  • 23,309 posts
Posted 19 December 2020 - 09:57 PM
To get any meaningful improvement the head needs to have some work done on it. The head design is the biggest restriction to improved performance with the A-Series.
In particular the inlet and exhaust ports need to have the restrictions caused by the very intrusive valve guide bosses removed. If you can get hold of a copy of Vizard's 'bible', How to Modify the A-Series Engine' it shows how a relatively small amount of work will give a good improvement.
Then you need to flow the inlet manifold a bit to enable the induction mixture to flow in and fit a better exhaust manifold to get the old gases out.
Get the compression ratio to between 9.75:1 & 10:1. Accurate measuring and machining is needed to do this.
#5 unburntfuelinthemorning
  • 1,985 posts
Posted 20 December 2020 - 08:28 PM
Modified 998s are great fun, it's what I have.  They aren't hugely fast but they are very enjoyable to drive.
A 1.5" SU will be fine for that setup.
With the ignition you can have your existing distributor advance curve altered to suit although it's always a bit of a compromise or you can go the whole hog with a fully programmable distributorless system.  Either will do, you'll get the best results with the latter but you'll spend a lot more.
A 10:1 CR running super unleaded should work nicely.  Just get it set up properly.
Think about the final drive ratio too, it makes a big difference.  A 3.76:1 ratio makes a 998 quite rapid if you don't mind 5000 rpm at 75 mph cruising in forth.
#6 3VILC
3VILC
  • 61 posts
Posted 21 December 2020 - 08:52 AM
Watching opinions with interest as I'm thinking along the same lines for my 998, once I've finished cutting all the rust out
#7 OzOAP
OzOAP
  • 387 posts
Posted 21 December 2020 - 11:02 AM
Done a few in the last couple of years.
1040cc,(+060), Mini 7 spec modified crank and rods, Steel flywheel/backplate, Piper 255 cam, 295 head with 33x29 valves, 10:1 cr, conical springs, 3.4 cwp.
2xHS2. Low 70s hp/ Mid 60s torque. Lovely fun, drivable, cars.
#8 Maccmike8
Maccmike8
  • 1,101 posts
Posted 21 December 2020 - 11:17 AM
Be worth having a chat with Calver if you are also buying their head.
If you are reboring then get the 2005 head as it has slightly bigger valves.
#9 whistler
whistler
  • 1,813 posts
Posted 21 December 2020 - 11:46 AM
As above, talk to Keith. he'll advise you what to put together with his head.
#10 andyapanel
andyapanel
  • 624 posts
Posted 21 December 2020 - 01:44 PM
Read Vizard and run any proposed mods past your insurance company.
I would eliminate ignition problems by fitting electronic ignition and put a fuel filter in keep the carb happy.
A lightened flywheel makes a great difference, as Dusky said.
Fit an RC40 or Manifold system plus a K+N.
Good luck and enjoy what you create.
