The Right Resistor Value For The „No Airbag Conversion“ Which Ohm Is Right?
4 replies to this topic
#1 Bergi
Bergi
  • 11 posts
Posted 20 December 2020 - 03:00 PM
Hello, could somebody tell me the right value of the capacitor that is needed to turn out the SRS light? Ive seen there are several different versions, from 2.2 ohms -> 3 ohms or even more. Would like to change my steering wheel to a wooden one. Therefore I need the right capacitor... thank you so much! Br Christoph
#2 weef
weef
  • 496 posts
Posted 20 December 2020 - 03:17 PM
Resistor values are measured in OHMS and capacitors values are measured in MICRO FARADS. If you are looking for an ohmic value buy a variable resistor that covers the range you expect to be in, connect it in circuit and adjust the value until the lamp clears. You can leave this in circuit or you can measure the value and buy the nearest preset fixed value resistor and install that.
#3 Tones61
Tones61
  • 430 posts
Posted 20 December 2020 - 04:30 PM
Search on eBay,I got one for my mpi for airbag delete ,2.2 seems familiar
#4 Spider
  • 14,946 posts
Posted 20 December 2020 - 06:08 PM
I've just edited the title to more accurately reflect the subject.
#5 Bergi
Bergi
  • 11 posts
Posted 03 January 2021 - 09:24 AM
Thank you so much, okay then I search for a 2.2 ohms resistor?! Br Christoph
