Torque Spec For 998 Head Studs
Best Answer Spider , 22 December 2020 - 05:02 PM
Have a read here, it will help you ID what Studs you have and the correct Torque to do them up to;-
https://www.theminif...studs-and-nuts/
Go to the full post
5 replies to this topic
#1 red_box
red_box
    Just On Tickover
  • 9 posts
Posted 22 December 2020 - 12:42 PM
Hi, I'm rebuilding a 1988 998cc A+, keeping it all stock.  Head studs were removed from block and rocker shaft pedestal studs  were removed from head during  engine disassembly.  Now I can't find any manual that gives the torque specs to fit the studs to the block and to the head.  (So I'm not after the torques for the nuts to fit the head and the rocker shaft - those are in the manual)
Searching the web, I've found this:
head to block studs:  42 lb/ft
rockers shaft pedestals to head stud: 22-25 lb/ft
...but on an thread here,  60lb/ft is given for the head to block studs ..?
Anybody know what the right specs are?
Edited by red_box, 22 December 2020 - 12:58 PM.
#2 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 22 December 2020 - 01:47 PM
Spin the studs into the block hand tight then simply torque the nuts up in sequence when the head is on.
When it comes to running the engine, use plain water until the head gasket seals
Edited by cal844, 22 December 2020 - 01:48 PM.
#3 Spider
  • 13,901 posts
Posted 22 December 2020 - 05:02 PM   Best Answer
#4 red_box
red_box
    Just On Tickover
  • 9 posts
Posted 22 December 2020 - 08:50 PM
Thank you cal844 .  Buy why only water in the initial engine run-in, instead of water + coolant mix?
#5 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 22 December 2020 - 09:42 PM
Only water makes the gasket swell quicker than with coolant mix, it's whats recommended on here and I can confirm it does work
#6 Dusky
Dusky
  • 5,322 posts
Posted 22 December 2020 - 09:52 PM
Doesnt make a gasket swell. Its because coolant mix is more capillary than pure water.
Edited by Spider, 23 December 2020 - 07:31 AM.
Keep it friendly please
