Hi,
I'm replacing the front discs, calipers and hoses (from the subframe mount to the caliper) on my 1989 Mini Thirty. As I understand it, the braking system is split into two circuits: front and back. Since I don't intend replacing the rear drums (they were replaced recently) I was hoping to be able to completely drain the front circuit without affecting the rears. Is this possible?
If I can drain the fronts, what order should I bleed them in... the side closest to the master cylinder first, or the side farthest away?
Chris
