Rocker Arms Too Worn?
Best Answer ACDodd , 22 December 2020 - 10:43 PM
Replace them.
Ac Go to the full post
7 replies to this topic
#1 red_box
red_box
    Just On Tickover
  • 9 posts
Posted 22 December 2020 - 09:20 PM
Hi everyone.  I'm rebuilding a 1988 998cc A+
All the rocker arms all show wear on the pads, like this:
Attached File  middle_rockers.jpg   35.4K   3 downloads
But the ones at the ends of the shaft have a deeper indentation, they look like this:
Attached File  end_rockers_1.jpg   25.03K   2 downloads
... and the one at the other end:
Attached File  end_rockers_2.jpg   31.26K   0 downloads
Do I need to replace all the rockers?  or just the 2 at the ends of the shaft?  or can they be somehow reconditioned?
#2 MiniMadRacer
MiniMadRacer
  • 899 posts
Posted 22 December 2020 - 09:23 PM
They do look past it to me, but I have never seen ones that worn before.. were the tappets as they are often called adjusted properly or were they hammering away.... I would check the shaft and valve guides for wear too
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 22 December 2020 - 10:43 PM   Best Answer
Replace them.
Ac
#4 Spider
  • 15,684 posts
Posted 23 December 2020 - 12:47 AM
They can usually be re-ground, but those are even past that.
Replace.
#5 red_box
red_box
    Just On Tickover
  • 9 posts
Posted 23 December 2020 - 10:26 AM
Disassembly started as soon as I got the engine, never ran it, so no idea of the rockers' 'life history'.   I checked the guide-to-stem clearance and found half of them were out of spec so replaced all of them. Also new valves.
#6 red_box
red_box
    Just On Tickover
  • 9 posts
Posted 23 December 2020 - 10:27 AM
Just wondering, why is it that the pads on the 2 rockers at the ends of the shaft are the most worn ones.  Could it be they don't get as much lubrication as the middle ones?  or they get exposed to more heat / less cooling?
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 23 December 2020 - 11:26 AM
Heat treatment was probably so so consistent on those items.
Ac
#8 imack
imack
  • 2,372 posts
Posted 23 December 2020 - 12:05 PM
Used to see a lot of rockers with that kind of wear, or even worse, back in the day.
