Exhaust System Assembly
11 replies to this topic
#1 I hate Brian
I hate Brian
  • 782 posts
Posted 23 December 2020 - 04:25 PM
Hi all anyone got some advice on getting a new single box RC40 system to seal I'm struggling at the Y piece and rear box clamps are tight as my mate at the bar !'ve even welded little bars across the clamps to stop them spreading
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 23 December 2020 - 04:27 PM
How far off is it? Exhaust gum is pretty good.
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 23 December 2020 - 04:28 PM
Did you use exhaust paste? If the joints are assembled dry they will leak.
#4 I hate Brian
I hate Brian
  • 782 posts
Posted 23 December 2020 - 04:43 PM
Seems to blow out the slots and no I haven't  used any paste as I can't find the muther I do have some
#5 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 23 December 2020 - 05:22 PM
If it’s blowing out of the slot on the link pipe it’s not on far enough.
#6 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 23 December 2020 - 06:47 PM
This, you can weld the slot slightly but try sliding it on more
#7 I hate Brian
I hate Brian
  • 782 posts
Posted 23 December 2020 - 07:57 PM
I've had a rubber mallet trying to work the tubes further in to the y piece and the rear silencer is butt up, better look for the paste a bit more thoroughly
#8 Midas Mk1
Midas Mk1
  • 5,823 posts
Posted 23 December 2020 - 08:01 PM
Did you rub down the y piece / link pipe before fitting to make sure it’s smooth with no rough bumps, old paste / corrosion. Usually helps, along with some decent firegum.
#9 MiniMadRacer
MiniMadRacer
  • 899 posts
Posted 24 December 2020 - 12:49 AM
Where possible I always try to assemble the exhausts parts off the car and make sure they all slide in together easily and far up inside as far as it shoudl go.... saves a lot of faffing lying under the car struggling later, but I appreciate that its not always possible to assemble off the car, but as said above make sure the pipes are clean rust free etc no burrs,, I have also opened out split pipe a bit knowing the clamps can be used to pull the metal back down tight together once things are all slid up
#10 croc7
croc7
  • 878 posts
Posted 24 December 2020 - 04:34 PM
To fully seat the joints, using WD40 on the sliding parts, clamp them down using stainless steel exhaust clamps from 7enterprises.  Works for me. Clamp Set, Stainless, LCB Standard Bore (SIE041
Edited by croc7, 24 December 2020 - 04:37 PM.
#11 I hate Brian
I hate Brian
  • 782 posts
Posted 24 December 2020 - 05:52 PM
Hi Croc7 I have ordered something similar W2 MIKALOR Stainless Super Heavy Duty Hose Clamp Exhaust Pipe Turbo Supra Clamps
#12 croc7
croc7
  • 878 posts
Posted 26 December 2020 - 12:50 AM
Those should work, I'm happy with the ones that I used.  Got tired of fighting the others and once on, not sure they were all that effective without the use of exhaust paste.
