Not Getting Spark, Need Tips Please!
3 replies to this topic
#1 RHDmini74
RHDmini74
  • 167 posts
Posted 25 December 2020 - 03:34 AM
So I’m having issues getting spark on my new engine. Getting power to the coil and to my electronic 45d distributor. Just no spark coming out of the leads from the center of coil or cap. New cap, rotor and wires. This same exact setup worked in my old engine a couple weeks ago before I pulled it. Idk what else to check. I’ve also tried 3 different coils and all get power but no spark? Thanks for any help!
#2 bpirie1000
bpirie1000
  • 2,539 posts
  • Local Club: Amoc
Posted 25 December 2020 - 09:04 AM
Is this points or converted to electronic ignition?
Is the coil Ballast or non.
What voltage have you got at coil?
#3 RHDmini74
RHDmini74
  • 167 posts
Posted 25 December 2020 - 06:58 PM
Electric, i think is a non ballast, its a bosch blue coil that has been working great for the last year or so. 12v at + & -
#4 weef
weef
  • 543 posts
Posted 25 December 2020 - 08:06 PM
Electronic distributors will only give an output if turning at at least cranking speed, they cannot be set up like a points distributor and hope to get a spark i.e. when the points open a spark is generated.
Set the engine at the desired TDC figure and adjust the distributor so that the "peak" on the rotor shaft is in line with the hall effect sensor.
this will set the static timing. Usually the distributor wires, red and black, are connected across the coil. Now check there is 12v at the coil positive terminal both with the ignition ON and when cranking the engine.
Fit the rotor arm, distributor cap and plug leads and crank the engine to check for a spark. If the integrity of the arm, cap and leads are good and the 12v is there but still no spark then look for a fault in the distributor itself.
When started use a strobe timing light to fine tune the timing.
This is only for a negative earth system.
