Hydrolastic Displacer Question
4 replies to this topic
#1 Zami
Zami
  • 169 posts
Posted 28 December 2020 - 03:43 PM
Anyone know what type of rubber was used in the making of the hydro bags? Silicon rubber?
#2 whistler
whistler
  • 1,822 posts
Posted 28 December 2020 - 03:46 PM
Ask Ian Kennedy. https://www.facebook...340758399381783
#3 mab01uk
mab01uk
  • 12,546 posts
Posted 28 December 2020 - 04:10 PM
Also lots of Hydrolastic information here in link below which may help:-
https://www.theminif...it-gold-plated/
Edited by mab01uk, 28 December 2020 - 04:11 PM.
#4 Spider
  • 15,160 posts
Posted 28 December 2020 - 06:35 PM
There was a couple of different rubbers used for the different components. The Rubber for the Spring is described only as ' Natural Rubber of a Highly resilient mix ', I dare say, Dunlops and Moulton likely keep the precise info close to their chest, though I feel it's similar to that used in the Rubber Cones. The Diaphragm that takes the Pressure of the System is a Nylon Reinforced Rubber in to which they molded 2 steel beads, similar to those in a tyre, these are the parts that were crimped into the steel housing of the units.
As a side note, these must have cost BMC an absolute fortune to make and fit, even as a mass production item, it's easy to see why Leyland discontinued them. There were extraordinarily well designed and made, given that there is still to this day, so many units still working well, the most common cause of failure seems to be rusting of the steel barb that the hoses are crimped on to.
#5 Zami
Zami
  • 169 posts
Posted 29 December 2020 - 12:04 AM
Thanks everyone for the input.
