Renewing The Clutch
Posted 31 December 2020 - 07:39 PM
Now I'm going to buy this:
- Pre Verto clutch arm
- Clutch Plunger pre verto
- clutch oil seal
- both clevis pin
Something else that I may be forgetting ??
Regards, Luis
Posted 31 December 2020 - 08:42 PM
I think thats about it bar maybe the master cylinder... I would replace the rubber pipe and I would use the uprated stuff from Mini spares
Posted 01 January 2021 - 11:21 AM
I replaced the clutch in my 81 pickup in August 2019 and I used that release bearing.. the cost is minimal difference over the std one so personally I would use that one.. I fitted it had no issues at all with it but then to be fair apart from a run fom London to Bristol it hasnt moved much lately.. I also fitted the Orange diapragm albeit with the std GT clutch plate
Posted 01 January 2021 - 11:36 AM
Posted 01 January 2021 - 11:41 AM
I didnt buy the kit I tend to upgrade where I can if it doesnt ruin the originality... I am sure there is nothing wrong with the kit one
Posted 01 January 2021 - 01:25 PM
The expensive one gives more stability to the diagphragm yes.. reduces any tendency for "wobble" and reduces any shudder / judder
Posted 01 January 2021 - 01:30 PM
Sure its double the price at £15 but the effort in going to change it and the amount of times you will be doing it (once hopefully) I saw it as worth it.... for sure others may not agree
Posted 01 January 2021 - 05:08 PM
And what about the 'plate', any specially good for pre-verto type?
Luis
Posted 01 January 2021 - 09:03 PM
Posted 02 January 2021 - 09:33 AM
Posted 02 January 2021 - 09:44 AM
Competiton bearing, Orange diaphragm and STD friction plate is what I would fit, but do bear in mind this setup requires more effort to push the clutch pedal so if you do lots of sitting in traffic you may not like the heavier feel to the clutch
Posted 02 January 2021 - 02:36 PM
Kind regards, Luis
Posted 02 January 2021 - 03:19 PM
Edited by Minigman, 02 January 2021 - 03:21 PM.
