Hi, please can you confirm they are 3/8 unf?
Car is an 87 998 but Im fitted 7.5" brake disc conversion.
Thanks Mike.
Posted 02 January 2021 - 02:34 PM
Thanks Mike.
Posted 02 January 2021 - 02:48 PM
This could be fun.
what callipers are you fitting?
yes the original spec was 3/8 UNF.
Posted 02 January 2021 - 02:55 PM
Posted 02 January 2021 - 03:51 PM
Thanks folk. They are AP 7.5".
Posted 02 January 2021 - 08:15 PM
The Originals as the other guys have said, were 3/8" UNF, however, some of the new types are M10. I would think those marked AP would be imperial though.
It can be hard to pick the difference between M10 and 3/8" UNF, however, they should never be interchanged as there's around 0.5 mm difference between them. Try a Bleed Nipple in a good wheel nut, if it fits, it's 3/8" UNF, if it doesn't, then M10 x 1.0.
Posted 02 January 2021 - 08:33 PM
Thank you.
Posted 03 January 2021 - 09:27 AM
Would the rear wheel cylinders be 3/8 too?
Posted 03 January 2021 - 09:49 AM
The originals were 1/4" UNF, but all the replacements I've had in the last 20 years or more have been either M6 or M7.
Posted 03 January 2021 - 10:19 AM
Thanks Spider.
Posted 03 January 2021 - 11:03 AM
Yes as Moke says above. The nipple was 6.2mm (1/4 in) and is now a 7mm head
Posted 03 January 2021 - 12:29 PM
Youve confused me with the head size. I just want to know the thread and pitch size, is that still 1/4 unf?
Posted 03 January 2021 - 12:35 PM
1/4 UNF
Posted 03 January 2021 - 12:39 PM
It it's to replace the nipples the safest bet would be to remove 'em & test in a known thread. Plenty of 1/4 & 3/8 unf nuts on a Mini.
