I was recently quized about the off-sets for off-set Boring the Big Bore Blocks for taking them out to 1380 and 1400 sized capacities.
I gave my friend the off-sets I've always used, which are those from David Vizard's How to Modify your Mini. He came back to me a short time later after consulting his own copy with some " ???? What ???? ".
After re-reading his notes a couple of times, I grabbed my own copy and check it, then compared to a photo of the same page in his book
I have a hard cover copy and upon checking that,,,, watch out !
The book in the back ground (my hard copy) is incorrect.
That in the foreground is correct !
I wonder how many followed this and got it wrong ?
I can't tell from either of these books when they were printed and if one is a particular later re-print than the other.
Check, then check again. Then to be sure, check again! Measure 3 times, cut once !
