Hi
Rebuilding the Mpi engine and have Swiftune SW05 cam, minispares duplex gear, MED 1.3 roller rockers.
No details with cam or rockers.
I measured cam timing dot to dot 105deg, bought 2 deg offset Woodruff, checked and we're at 106.5deg. I was aiming for 107 by my research.
I thought maybe a touch near the bottom end of the range here when taking any potential stretch into account.
Any advice, I'd rather not do it again if possible but if it's for the best then no problem?
Valve clearances 13 thou ok?
Paul
Cam Timing
PiG
, Jan 08 2021 08:33 PM
4 replies to this topic
Posted 08 January 2021 - 08:33 PM
Posted 08 January 2021 - 09:23 PM
I'm sure the SW5 paperwork says it needs to be 15 thou.
Posted 09 January 2021 - 10:41 AM
I think you need to talk to Swiftune as it's their cam.
Posted 09 January 2021 - 11:28 AM
Done that also.
Posted 13 January 2021 - 05:38 PM
Just to update in case anyone needs it, I spoke to them today and they are sending me the leaflet that should have been in the box (may well have been )
Response was as follows for figures though
Range is 106 to 108. For an MPI the 106.5° timing will be fine, even taking into consideration the chain slack that will occur. Your tappets should be 0.015” with those rockers.
