Filter King
16 replies to this topic
#1 Trissy B
Trissy B
  • 381 posts
  • Local Club: Bognor Regis Motor Club
Posted 09 January 2021 - 03:25 PM
Thinking of getting one as swapping the pump. 3 questions.
How do you actually adjust the pressure? From the photos I can't see how you would and is there accurate settings?
If you get one with 8mm fittings,can these unscrew so you can use 6mm instead?
I think the small has a 65mm bowl. Guess this is fine for the min but is the bigger OK too? (85mm).
I've found a second hand one at 85mm bowl x 8mm in/out. Any experience very welcome.
#2 hazpalmer14
hazpalmer14
  • 684 posts
  • Local Club: cumbria mini cruisers
Posted 09 January 2021 - 03:29 PM
You attach a fuel pressure gauge to the output and there will be a screw that winds in and out to adjust pressure.
#3 imack
imack
  • 2,195 posts
Posted 09 January 2021 - 04:23 PM
Some come with a tapping in the top where you can screw in a pressure gauge. I drilled and tapped mine to accept a gauge to set the pressure via the adjustment screw and lock nut on top of the unit. Remove gauge once set and screw in a blanking plug.
#4 Trissy B
Trissy B
  • 381 posts
Posted 10 January 2021 - 08:24 AM
Thanks guys didn't realise you had to buy the pressure gauge too.
#5 Trissy B
Trissy B
  • 381 posts
Posted 10 January 2021 - 08:57 AM
This is what I am looking at. Not sure if it's too big for 1275 on Hif44.
https://www.ebay.co....4.m46890.l49292
#6 imack
imack
  • 2,195 posts
Posted 10 January 2021 - 09:26 AM
I think mines only the 65mm version, fittings are 8mm but located differently to the one you're looking at.
The one in your picture has the plug that can be removed and a gauge fitted.
#7 nicklouse
  • 18,682 posts
Posted 10 January 2021 - 09:39 AM
Buy new. The diaphragm could well be rotted.
#8 no66
no66
  • 156 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 11 January 2021 - 11:09 AM
Some of them come with a 6 to 8 mm combo fitting.
If I remeber correctly the base setting pressure will be in the ballpark for an SU at 3.5 psi that is lower than most electric fuel pumps
Get the 65mm glass bowl.
Edited by no66, 11 January 2021 - 11:11 AM.
#9 Ethel
  • 26,056 posts
Posted 11 January 2021 - 07:55 PM
You used to be able to pinch them off Alfa's back in the day. You don't need a gauge, you can adjust it to starve the carb then bring it back just enough, but a gauge needn't be expensive.
https://www.fuelpump...arts-5084-c.asp
I think Merlin carry some parts too
#10 Trissy B
Trissy B
  • 381 posts
Posted 12 January 2021 - 02:02 PM
Great thanks for the replies, I think I will go for a new 65mm one.
I thought the pressure for a hif44 was more like 1.5 psi??
#11 m445
m445
  • Just Joined
  • 32 posts
Posted 12 January 2021 - 02:32 PM
I recent got a pressure regulator and filter to feed the HIF44 carb.  This regulator has markings to set pressure.  I will add pressure gauge to check also.
Mr Gasket 9710 pressure regulator
https://www.amazon.c...p_MgB.FbZQ56XBQ
Mr Gasket Filter 9706
https://www.amazon.c...p_2jB.FbMTJGCY6
#12 PACINO
PACINO
  • 764 posts
Posted 13 January 2021 - 03:14 PM
Hi. I have had a Malpassi Filter King installed in the Mini for years. It was the glass version, which is very useful to see the status of the filter.
https://www.minispar...|Back to search
I recommend that you buy it with a pressure gauge, and thus regulate the exact fuel pressure that your carburetor needs.
Regards
#13 Ethel
  • 26,056 posts
Posted 13 January 2021 - 03:39 PM
I don't think pressure will be that critical or a universal constant for all SUs.
You'd have to look at the float's displacement, leverage, valve orifice area etc - but I'd hazard a guess it'd take quite a bit more fuel line pressure to force it to open.
Where the pressure will matter is in allowing a high enough rate of flow when the float drops and that'll depend on the rate the fuel is sucked in to the engine i.e. its horsepower.
Even so, never heard of any needing more than 3psi
#14 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 13 January 2021 - 03:43 PM
Minor comment but "racer" rules dont allow the glass bowl (usually) for obvious "breakage reasons", fine for the road I believe but do be aware they break easy, so once fitted be careful when spannering in that area, only needs a little tap from a spanner or a ratchet
#15 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 13 January 2021 - 10:31 PM
Is it possible to buy a metal bowl as a replacement for the glass item?
