It's been nearly 2 years since I stripped the mini. I cant for the life of me remember the exact location of the expansion tank. The car is a 93 tahiti 1275 carb model. I know it goes under the nearside wing, but where? Any help would be great
Expansion Tank.
Simon H
, Jan 10 2021 11:13 AM
3 replies to this topic
Posted 10 January 2021 - 11:13 AM
Posted 10 January 2021 - 12:02 PM
Looking under the near side wing it goes to the right of the shock absorber. You should be able to see 3 holes in the inner wing that the securing bracket bolts go through.
Posted 10 January 2021 - 12:33 PM
I can see the 3 holes that held the bracket for the charcoal canister. My expansion tank has a U shaped bracket with only 1 fixing bolt!
Posted 10 January 2021 - 08:39 PM
Simon it's just to the left of the shock. I think it was originally fitted with a rubber strap but I've just used a long zip tie that loops around the tank and threads through the inner wing. There's not much weight in it, it holds in place.
