Tips For Removing Rear Subframe Mounts/support Pin
7 replies to this topic
#1 mattrsa
mattrsa
  • 120 posts
Posted 12 January 2021 - 05:47 PM
Hi All
Have the rear subframe out the car to rebuild, while i'm at it I thought I would replace the bushes but for the life of me I can remove the rear ones from the frame. I have of course undone the big nut which hold them to the frame and they will wiggle round but when I try pull/hit the rear subframe support pin it will not come out.
Any tips would be great as this is driving me mad.
thanks in advance
#2 richmondclassicsnorthwales
  • 942 posts
Posted 12 January 2021 - 06:12 PM
If you have a good vice which is bench mounted would help
The pins rust onto the subframe as there is not a lot or wriggle room.  What I have done is put the head of the support pin in the jaws of the vice - then rotate and chatter the support pins, twisting the subframe back and forwards - side to side.  You can use a bit of heat, just be careful obviously
Putting the head of the support pin in the jaws of the vice does require the subframe stripped of everything - so you are only wrestling with the pin and subframe
They are a pain - I am sure a few other members can add their techniques of how they have got the pins out - this was mine.
#3 mattrsa
mattrsa
  • 120 posts
Posted 13 January 2021 - 01:15 PM
thanks for the reply.
I have bought new poly bushes for the subframe but feel like it might be more hassle than its worth to replace them.
Will try as suggested and report back
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 13 January 2021 - 02:23 PM
Spray liberally with penetrating fluid (PlusGas or similar) and then use good grips to get the pin turning - keep working it until it turns relatively freely.  Once it does use the grips to turn and pull it at the same time.
I would certainly replace the bushes if you're this far in - they do degrade over time and will not be holding the subframe as securely as they should, compromising the handling. Personally I wouldn't use poly bushes here.
#5 mattrsa
mattrsa
  • 120 posts
Posted 13 January 2021 - 03:02 PM
Thanks Graeme
Just out of interest why would you not use poly bushes? I'm a bit of a novice here and just bought them as thought they would be better.
#6 GraemeC
GraemeC
  • 7,440 posts
Posted 13 January 2021 - 03:21 PM
They simply are just the wrong material - not compliant enough and tend to permanently deform.  Effectively they give plastic deformation rather than elastic.
Lots of thoughts on the forum, one thread here:
https://www.theminif...sh#entry3538906
#7 mattrsa
mattrsa
  • 120 posts
Posted 13 January 2021 - 03:46 PM
thanks i will read up
#8 mattrsa
mattrsa
  • 120 posts
Posted 14 January 2021 - 08:46 PM
quick update
after soaking it with penetrating fluid and wiggling, twisting and pulling on it I have finally got one side off.
