Turbo Manifold Gasket
Posted 13 January 2021 - 06:15 PM
Just received a turbo manifold gasket from Retrominis, it has a metal side and a fabric type side, which way does it go on the car metal to cylinder head or metal to inlet ?
Thank you 🙏
Posted 14 January 2021 - 06:21 PM
Had a read and from what I can gather the metal side faces the inlet manifold and the fabric type side again the engine block ?
Posted 14 January 2021 - 06:51 PM
Hi Lee,
From memory when I fitted mine, the metal side goes against the head and the exhaust fire rings sit against the exhaust manifold ports.
If you think about it, the metal side would sit against the head face so that you have flat metal against flat metal. Then the fire ring side match up with the manifold exhaust ports.......... I think!
Cheers, Steve.
Posted 14 January 2021 - 07:04 PM
Hi Lee,
Cheers, Steve.
That was my thought to be honest as last time I fitted it metal to the manifold and gasket not to the head and spend ages scraping the gasket off the head
Posted 14 January 2021 - 08:14 PM
Minispares website is saying metal to manifold and alot of conflicting answers on here 🤷♂️ Very confusing
Edited by leepol83, 14 January 2021 - 08:15 PM.
Posted 15 January 2021 - 02:50 PM
Posted 15 January 2021 - 04:05 PM
Ring Metrominis and ask the question
Posted 15 January 2021 - 05:10 PM
Tried no answer hence why I’m asking the question on here ? 🙏Ring Metrominis and ask the question
Edited by leepol83, 15 January 2021 - 05:12 PM.
Posted 16 January 2021 - 09:01 AM
Hi again Lee,
After some more googling I found the below statement on Minispares website. It’s a description for fitment of the manifold to injection Minis but states this gasket can be used for turbo installations as well.
so to recap, it looks like metal face towards manifold!
Cheers, Steve.
smooth metal side goes towards manifold
Posted 16 January 2021 - 09:34 AM
Thanks SteveHi again Lee,
Cheers, Steve.
Special reinforced gasket for injection cars has metal inserts on exhaust ports plus a metal back on the manifold side which makes surface easier to clean when replacing. Often used on Turbo cars now when correct gasket is in short supply.
Found the same statement so I’ll go with that Thanks buddy for the help, going to do it today 🤞🏻 Thanks again
Edited by leepol83, 16 January 2021 - 09:37 AM.
Posted 16 January 2021 - 05:53 PM
You’re most welcome Lee,
Good luck and I hope it all goes OK.
Cheers, Steve.
Posted 17 January 2021 - 06:31 PM
Cheers, Steve.
Quick update metal side to manifold works a treat 👍🏻 All sorted
Posted 17 January 2021 - 07:02 PM
Well done Lee
