My question is, is there an easy way to get to the to little bolts on the front plate of the top arm pin? Or is it just a case of dislocating my arm in multiple places? 😂
Edited by Ado1379, 14 January 2021 - 07:27 PM.
Posted 14 January 2021 - 07:27 PM
Posted 14 January 2021 - 07:39 PM
From the front with extensions.
remember only one is a captive nut.
Posted 14 January 2021 - 08:08 PM
Posted 14 January 2021 - 08:14 PM
Posted 14 January 2021 - 08:44 PM
I've moved this to the General PTQ as you'll get a wider response.
Posted 15 January 2021 - 08:29 AM
I would check / replace the front bump stops, the little bits of rubber that cushion the arm dropping, and check for play in the swivels / knuckle, and similarly check the Track Rod ends and the CV gaiters, and the tie rod bushes
Posted 15 January 2021 - 08:37 AM
Edited by Ado1379, 15 January 2021 - 08:37 AM.
Posted 21 January 2021 - 04:51 PM
I thought this might be the case, still can’t hurt to ask!
Has anyone used the mini spare evolution cones? It says on the website that they’re relatively new. I’ve replaced the rears along with the subframe and shocks and bushes. I’ve reamed and rebuilt my radius arms too. Apart from greasing everything up, can anyone suggest anything on the front that’s worth replacing whilst it’s up on stands? Thanks
Interesting! I have been running their red-dot competition cones for over 10k miles now. Wonder how these new ones compare.
Posted 21 January 2021 - 07:31 PM
Posted 31 January 2021 - 10:03 PM
