I'm replacing my wiper motor and the connectors in the plug are corroded.
Is there any benefit to replacing the plug (one of these http://www.minispare...sic/520161.aspx) over just crimping some spade connectors onto the wires and connecting those directly to the parking switch?
Wiper Motor Plug Vs Spade Connectors
oohaargh
, Jan 14 2021 08:56 PM
3 replies to this topic
Posted 14 January 2021 - 08:56 PM
Posted 14 January 2021 - 09:10 PM
If you have the correct spade connectors then no problem, obviously use the spades without a sleeve (Blue/Red) as the correct spade connections use 2 small locking tabs to lock them into the plug.
Posted 14 January 2021 - 09:33 PM
I haven't got spade connectors to fit the plug, I mean using the covered connectors and fitting them loose onto the male connectors on the parking switch with no plug
Edited by oohaargh, 14 January 2021 - 09:33 PM.
Posted 14 January 2021 - 10:56 PM
Yes will work fine, but you can get the correct spades various places, inc ebay. Thats if you wanted to keep the oe look and use the plug
