Wheels And Suspension Set Up - Clearance
6 replies to this topic
#1 mattrsa
mattrsa
  • 120 posts
Posted 15 January 2021 - 09:11 AM
Hi All
In the middle of a part restoration of my car and am starting to think of wheels and tyres.
I have gone with red dot cones and hi lows with gaz lowered shocks as the suspension set up and done the 12 to 10 inch brake conversion.  I'm wanting to run 6x10 wheels either Minator or minilite.
Is there anything I need to consider in terms of clearance. Some sites selling appear to list the offset (-7mm) but others don't and I presume this is crucial to getting them to fit with no clearance issues.
Any help or advice would be much appreciated.
#2 MiniMadRacer
MiniMadRacer
  • 850 posts
Posted 15 January 2021 - 09:50 AM
I have never gone that wide on a road car, so the only thing I can add is you will need wheel arch extensions to cover the tyres (I am sure you had that on the list though), assuming its UK based (Legal requirement here to cover the tyre thread)
#3 mattrsa
mattrsa
  • 120 posts
Posted 15 January 2021 - 10:02 AM
thanks MiniMadRacer and Nicklouse
Wanted to run slightly lower than standard but having read various threads on the forum it seems that running red dots might make that tricky because as you mentioned they sit higher.
Yes with regards to arches these will be replaced with new appropriate sized ones. At the moment I have not really looked into this but I know there are a number of options.
#4 imack
imack
  • 1,872 posts
Posted 15 January 2021 - 10:07 AM
Pretty certain you'll need to cut the wings and front panel. My 6x10 +13mm offset minilites need the wings trimmed.
#5 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 15 January 2021 - 10:08 AM
As Nick has mentioned, you will no doubt need to trim the front arches for clearance.
There is a good arches directory on the forum, grab a coffee and flick through, will give you some ideas on which way you may want to go.
#6 nicklouse
  • 17,945 posts
Posted 15 January 2021 - 11:11 AM
Seems like you have had fun on this thread. Where did my reply go? At least the Op read it.
#7 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 15 January 2021 - 05:36 PM
I’m working off my mobile, clearly a glitch ...., or is that fat fingers?
Nick feel free to repeat yourself .....
