Wheel Bearings
11 replies to this topic
#1 nickthegreek
nickthegreek
  • 14 posts
Posted 15 January 2021 - 12:02 PM
Hello all,
Advice please, wheel bearing grease? Best one?
Nick
#2 nicklouse
  • 17,929 posts
Posted 15 January 2021 - 12:05 PM
The one that comes with them. Which is a general lithium based grease. Which will be the same as you use on all other grease points.
#3 MiniMadRacer
MiniMadRacer
  • 850 posts
Posted 15 January 2021 - 01:36 PM
I always find those supplied with them sachets, tend to be very small. I know you shouldnt over pack wheel bearings with grease but you may find not enough is actually supplied with the bearings
#4 nickthegreek
nickthegreek
  • 14 posts
Posted 15 January 2021 - 03:12 PM
no grease came with the bearings, hence the advice needed
#5 wilsonch
wilsonch
  • 107 posts
Posted 15 January 2021 - 03:47 PM
If you are totally OCD about it you can get Timkin red bearing grease its about 25quid a tub.
Search online you should be able to find some
Edited by wilsonch, 15 January 2021 - 03:48 PM.
#6 Dusky
Dusky
  • 5,322 posts
Posted 15 January 2021 - 04:25 PM
That’s not the same grease if you’re using disc brakes.
As a general standard you use a high temp grease on wheel bearings with disc brakes. Atleast, thats what SKF supplies.
#7 nickthegreek
nickthegreek
  • 14 posts
Posted 15 January 2021 - 04:27 PM
just need to know what grease is suitable!!!!!
#8 KTS
KTS
  • 2,254 posts
Posted 15 January 2021 - 05:01 PM
get this
https://mustangmania...ve_wheel_grease
..and do this
https://www.timken.c...With Grease.pdf
Edited by KTS, 15 January 2021 - 06:16 PM.
#9 nickthegreek
nickthegreek
  • 14 posts
Posted 15 January 2021 - 06:42 PM
thank you KTS
#10 wilsonch
wilsonch
  • 107 posts
Posted 15 January 2021 - 09:40 PM
Yeah thats the stuff.
What i meant by OCD was using Timken grease on Timken bearings. If thats the bearings you have, some dont use (or have problems with) no Timken.
#11 Spider
  • 13,884 posts
Posted 15 January 2021 - 11:58 PM
A quality, name brand High Temperature Wheel Bearing Grease will be fine, though I happily was using Castrol for many years, a few years back I found it had water in it and doesn't feel the same, it caused premature failure of 2 sets of bearings. I've gone away from that and to Timken's grease now.
#12 Tornado99
Tornado99
  • 746 posts
Posted 16 January 2021 - 08:29 AM
Steveston Motor Co mentions in one of their great videos to use proper bearing grease for any roller or ball bearing component, and leave moly type grease for ball joints and other bit without roller/balls involved. Moly is claimed to be too slippery and can inhibit rolling action on races.
