Twin Hs4 Carb Identification
Best Answer mvahora , 12 February 2021 - 09:53 AM
heard back from Berlen. This is their reply:
The needle ABK traces these to a triumph dolomite from 75 onwards, as fitted with the red spring.
However you appear to have a mixed pair of dolomite carbs, one from 75, one from 76, hence the small differences between the two. The 75 would have been spec number FZX 1005, THE 76 FZX 1051.
It looks like these have been paired together.
If the jets and needles are the same for both, I see no reason why this setup won’t run as intended.
So detail changes like needles jets and springs are carb specific, but carb bodies and service items like gaskets washers and o rings are generic.
As far as the dampers are concerned, you would be best served to run a matched pair, so 2x AUC 8114.
Go to the full post
12 replies to this topic
#1 mvahora
mvahora
  • 213 posts
Posted 16 January 2021 - 05:50 AM
I have a twin hs4 carb setup that has been refurbished (as per pic attached).  I'm trying to decipher which car they originally came off (my guess is an MG). There is no tag on them but I can see codes on the parts. I've listed them below.
Is it normal to have different codes on either side of a twin HS4 carb setup?
Codes:
Dashpot - Left PDC18, Right PDC14
Damper - Left AUC8103  Right AUC8114
Piston  - Left AUC1331B, Right AUC1331
Body - Left AUC1344, Right AUC1300 MOD3
Float Bowl  - BOTH AUC1310
Float Bowl Lid - Left AUD9203, Right AUD2277
Edited by mvahora, 16 January 2021 - 05:50 AM.
#2 steeley
steeley
  • Just Joined
  • 623 posts
Posted 16 January 2021 - 10:07 AM
Try mailing burlen
http://burlen.co.uk/
#3 Chris1275gt
Chris1275gt
  • 969 posts
Posted 16 January 2021 - 11:57 AM
I'd of thought that it would be normal to have different numbers for some parts as they are the same but left and right handed.
#4 richmondclassicsnorthwales
  • 942 posts
Posted 16 January 2021 - 04:35 PM
Without the specific tag, they could be off anything,
#5 mvahora
mvahora
  • 213 posts
Posted 16 January 2021 - 10:30 PM
Try mailing burlen
Good idea, will do. hopefully they can shed some light.
hmmm that's what I did have in mind but don't want to go bolting them onto my motor if the dampers for example need to be the same etc.
Edited by mvahora, 16 January 2021 - 10:31 PM.
#6 GraemeC
GraemeC
  • 7,451 posts
Posted 17 January 2021 - 11:10 AM
I’d be dubious if they ever started life as a pair
Edited by GraemeC, 18 January 2021 - 08:19 AM.
#7 mvahora
mvahora
  • 213 posts
Posted 17 January 2021 - 11:24 PM
I’d e dubious if they ever started life as a pair
Hmmm Would that have any effect on performance if they are different and have varying part numbers?
Ive emailed burnlen / SU. havent received a reply yet
Edited by mvahora, 17 January 2021 - 11:25 PM.
#8 Tds76
Tds76
  • 87 posts
Posted 18 January 2021 - 01:06 AM
If you have the time you can trawl through the tables and data sheets and see what they were originally fitted to.
http://www.oldengine.../SUCarbMenu.htm
As a reference and as you would expect, the data sheet for the 998 Cooper shows the majority of the parts are common between L & R carbs.
http://www.oldengine...tors/AUD104.htm
Cheers, Paul.
#9 GraemeC
GraemeC
  • 7,451 posts
Posted 18 January 2021 - 08:21 AM
Hard to tell without knowing the in's and out's of all the differences between part numbers and then how they interact with each other.
However I would certainly have expected the same piston, damper, dash pot and needle in each side.
I notice whoever refurbed them didn't even take the 2 seconds to make sure the spacers were orientated correctly, which would make me question the rest.......
Edited by GraemeC, 18 January 2021 - 08:23 AM.
#10 mvahora
mvahora
  • 213 posts
Posted 23 January 2021 - 12:05 AM
Cheers, Paul.
where do you guys find these legend websites lol.
Ill have a hunt through when i get some time and seee if i can find a match
Thanks so much
#11 mvahora
mvahora
  • 213 posts
Posted 23 January 2021 - 12:07 AM
Hmmm yes i will have to do some more digging. Ive emailed burlen but havent got a reply yet.
oh bugger thanks for pointing that out. ill change it over if i end up using them...
#12 62S
62S
  • 1,244 posts
  • Local Club: You must be joking!
Posted 30 January 2021 - 03:57 PM
Or make sure the dampers are a pair...
#13 mvahora
mvahora
  • 213 posts
Posted 12 February 2021 - 09:53 AM   Best Answer
