Hi all, easy one for you. What is this pipe for? Mine doesn't go anywhere, either end.
Best Answer Ethel , 16 January 2021 - 05:09 PM
Yes, It doesn't only let fuel out if it floods - it lets air in to equalise pressure in the float chamber. If it didn't fuel being sucked through to the engine would create a partial vacuum that stop the fuel flow.
Go to the full postPosted 16 January 2021 - 04:47 PM
Posted 16 January 2021 - 04:51 PM
fuel overflow from the carb
Posted 16 January 2021 - 05:00 PM
Oh right, so it should be open at the bottom of the engine end then?
Posted 16 January 2021 - 05:09 PM Best Answer
Posted 16 January 2021 - 05:21 PM
Righto cheers!
