Hi I am fitting a Magnum boot side floor section (40-10-88-1) and then a inner wheel arch stiffener (40-10-55-7) with a inner corner on the under side. My question is this do I sandwich the stiffener between floor section and the underside inner corner, or just fit it on the inside. Welding it to the floor section and the wheel arch ?
I am unable to use heritage down to the large amount of panels I will need to replace. This is a bad 80's mini !
