Engine And Gearbox Assembly, What Are These Left Over Parts For?
16 replies to this topic
#1 PiG
PiG
  • 144 posts
Posted 18 January 2021 - 03:50 PM
Looks like a locator tab for a sensor maybe?
O ring is 33mm by 2mm thick best I can measure it, suspect from the gearbox gasket set?
Car is Mpi.
#2 bpirie1000
bpirie1000
  • 2,118 posts
  • Local Club: Amoc
Posted 18 January 2021 - 03:52 PM
Oval one looks like a rocker tab!
Is the o ring not between gearbox and engine?
Edited by bpirie1000, 18 January 2021 - 03:53 PM.
#3 Spherix
Spherix
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 18 January 2021 - 03:54 PM
Yep, see part #24: http://minispares.co...d.aspx?2~12~111
#4 bpirie1000
bpirie1000
  • 2,118 posts
  • Local Club: Amoc
Posted 18 January 2021 - 03:57 PM
Number 35 for the seal?
http://www.minispare...ion.aspx?1~4~34
#5 sonscar
sonscar
  • 2,720 posts
Posted 18 January 2021 - 04:00 PM
Hope it is not the gearbox/engine o ring,might cause problems with oil pressure,Good luck,Steve..
#6 PiG
PiG
  • 144 posts
Posted 18 January 2021 - 04:02 PM
Yes, rocker tab so not needed as new set on, that's good thank you!
Not no.35 seal that's smaller and thicker and I know it's in.
I think now having searched through minispares it might be the gearbox metal plug at the base which I know I put one in there so not sure why there would be more than one in my kit though.  It was 2 years ago the box was built so hope my memory serves me well!
Edited by PiG, 18 January 2021 - 04:04 PM.
#7 danc
danc
  • Just Joined
  • 28 posts
Posted 18 January 2021 - 04:04 PM
Looks a bit bit thin section and large ovetall diameter for the box to block seal doesn't it?
What about the distributor seal?
http://minispares.co...px?1~10~85|Back to catalogue
#8 bpirie1000
bpirie1000
  • 2,118 posts
  • Local Club: Amoc
Good thinking PiG
Edited by bpirie1000, 18 January 2021 - 04:18 PM.
#9 bpirie1000
bpirie1000
  • 2,118 posts
  • Local Club: Amoc
Posted 18 January 2021 - 04:05 PM
Good luck.....
Normally i find my kidsmput extra bits in my boxes....
just to confuse the hell outta me so getting good at this guessing game..
#10 PiG
PiG
  • 144 posts
Posted 18 January 2021 - 04:06 PM
Good luck.....
:w00t: yes, that could well be the case here too!
#11 PiG
PiG
  • 144 posts
Posted 18 January 2021 - 04:09 PM
Thank you, possibe it was in my engine gasket set, not needed for mpi
#12 GraemeC
GraemeC
  • 7,313 posts
Posted 18 January 2021 - 04:46 PM
If it is from the gasket set, it is probably the seal for the bell crank pivot pin, #27
http://www.minispare...ive.aspx?1~4~42
I don't change these unless there has been a known leak.
Edited by GraemeC, 18 January 2021 - 04:47 PM.
#13 nicklouse
  • 17,935 posts
Posted 18 January 2021 - 05:16 PM
Generally still needed or your shaft can rotate and you lose the oil feed to the rockers not to mention the grub screw having conversations with the valve train.
#14 PiG
PiG
  • 144 posts
Posted 18 January 2021 - 05:22 PM
Good to know, thank you for that.
#15 Tones61
Tones61
  • 423 posts
Posted 18 January 2021 - 06:35 PM
Dizzy seal ?
